I use a usb connection to capture video from my mini dv digital camcorder
The quality is not good. Do i need a firewire connection ?
Firewire or Usb to capture ?
Check your camcorder user's manual. There really shouldn't be a difference, because with a digital camera, you are just transferring digital data (bits & bytes) from the camcorder.
But, some camcorders do seem to send lower resolution over the USB port. This is probably to keep everything compatible with USB-1, which is much slower than Firewire or USB-2. (With USB-1, it would take forever to transfer high resolution video.)
heinz-oz
I beg to differ here, USB 2.0's sustained transfer rate is not up to handling full frame DV at full frame rates. I have not seen a MiniDV camcorder sending full frame DV over the USB connection. It's usually a much smaller frame size and reduced frame rate, which is ok if you want to use the footage for video streaming. If you want good quality you will need the firewire connection.DVDDoug wrote:Check your camcorder user's manual. There really shouldn't be a difference, because with a digital camera, you are just transferring digital data (bits & bytes) from the camcorder.
skier-hughes
- Microsoft MVP
- motherboard: gigabyte
- ram: 4GB
- sound_card: onboard
I'd agree with the majority here, definately firewire.
USB2 cannot sustain the data rate for full dvd. It has a burst speed higher than firewire, 480 to 400Mbps, but as it says this is burst and is not continuous. Whereas firewire offers continuous high speed.
Movie maker does not generally work with USB2.
Graham
Graham
