Saving Button Bar to HTML
learn4life
Post by learn4life »
I'm using the Component designer to create a button bar to use in a web page. I exported the button bar as "component opjects" and save it as UFO format in order to edit it later.
If I open the file to edit it, how can I save it as html again. That option only seem to be available when you first create the file and you export as HTML.
Thanks!
heinz-oz
Post by heinz-oz »
Changes you make to your UFO file are not reflected in the html you exported. You need to export it again after you have made your changes.
learn4life
Right! But I don't see the option to export to html, I only see that option when I orginally created the the document. Once I close and reopen the document that option is not present.
2log
re: Saving Button Bar to HTML
Post by 2log »
Click on the menu File > Save for Web > As HTML or click on [Ctrl]+[Alt]+ to save a UFO file as an HTML document... :wink:
