can't open avi file in ulead videostudio ver 9
doryshe
Post by doryshe »
I am using ulead video studio ver 9. I have a problem with avi files, when I am import video with avi format it tells me that I can't open the file.
why is that?
heinz-oz
Post by heinz-oz »
I guess it is because you can't open it. Sorry about the bad joke.
Where did your avi file come from? avi and avi and another avi can actually be three different things alltogether. VS should not, and usually doesn't, have any problem with a DV avi file captured from your digital camcorder.
What are the properties of your clip?
doryshe
Post by doryshe »
the funny thing is that I can't open the Avi file that came from the ulead. example the avi file that count the number 5 to 0.
In windows I can open the file without a problem.
I tried to reinstall the program
what did u mean about the properties?
doryshe
Post by doryshe »
with the error code: " unable to open AVI file [17101:7:1] "
heinz-oz
Post by heinz-oz »
Oh, ooohh, that I didn't expect :?
If you can't open the sample file from ULEAD??? This calls for a complete and utter uninstall of VS, delete the temp files, clear the registry of anything VideoStudio, re-boot your system and do a fresh install.
The file properties you can find by right clicking on the actual file and clicking 'Properties'
THoff
Post by THoff »
The inability to open AVI files is often caused by a missing or damaged codec. Before you uninstall UVS and clean out the registry, make sure that you have the Indeo Codec V5.10 installed -- this is the codec used by all of the Ulead sample AVI files. The codec comes with Videostudio, but you may have skipped the installation for it.
http://www.free-codecs.com/download/Indeo_Codec.htm
escobosa
Same problem
Post by escobosa »
I got the same message after I upgraded fron UVS-7 to UVS-9 if I try to import avi files, or if I try see the included video samples. I installed the codec once, but after I installed the extra content packs I got thhat message again.
I have no problems using Nero Vision Express (6.6) for the same files, I can encode them and burn to CD.
doryshe
It didn't work.
Post by doryshe »
I tried to do what your told me about the codec and the other things and it didn't work.
Is there another solution?
