Onscreen text is out of screen
medp7060
Post by medp7060 »
When I put onscreen text on any of the corners, some of the text is out of TV screen. Is there a way to chnage the position so the text will remain visible within the TV screen. I do not like to put it in the top or bottom centre.
bryave
title safe
Post by bryave »
You might need to set your title safe area. Try going to preferences by clicking File then click Preferences or simply by just pressing F6 onto your keyboard. Switch to Output Settings tab then look for Show title-safe area then set it to 0%. Click OK for changes to take effect and let's see if your problem is solved. ^_^
†bryave
medp7060
Post by medp7060 »
Thank you for your reply. Howevr, that only helps with the user input texts. The position of onscreen texts such as "File Name", "Date Taken" are still out of my TV screen. I think the positions (four corners) of those onscreen texts are not changed accodingly. In other words, they are not user-changeable.
bryave
test
Post by bryave »
I've tested it with my PC and it shows ok. I don't know why it doesn't work on yours. Would you try playing it to other TV. It might have something to do with hardware I guess. Does it previews fine on PC? Maybe you should try also other players? ^_^
†bryave
