re-encoding compliant video
DiscCoasterPro
Hello. I just learned something about DVD Workshop that I have been laboring over and thinking I was doing something wrong.
When working with compliant video files, it is my understanding now that DVD Workshop's encoder with re-encode all files no matter what. Can anyone tell me if there is a way around this, or if I can add additional encoder drivers to the choice list in DVD Workshop's Disc Template?
I didn't think that any higher end authoring program would come without an option to either encode or bypass compliant video.
thanks for your help,
DiscCoasterPro
Thanks for your reply. Let me ask this. I originally assumed that Workshop was re-encoding my compliant files based on the time it took to complete a project on my computer. When I inquireed on a video forum, the gentleman there informed me of this in workshop.
I have a p4 2.8HT with a Gig of dual channel pc3200 mem. A 4gig composition with menus and chapters can take 2 hrs to complete from the time I click on burn.
My question is, does this time frame seem about right for other users?
thank you,
thank you,
2 hours seems too long if it wasn't re-encoding.
Do you have alot of motion menus
As ploggy asked, do you get the option to "Convert to disc template" in the EDIT step (under the Video and Audio tabs)
What are the properties of your source videos
What are the properties of the disc you are creating? NTSC, PAL, etc...
George
DiscCoasterPro
thanks for the reply. No motion menus, nothing really crazy, a couple of submenus and a dozen chapters all together, thats it.
I deleted the project files and the source captures already but I will take specific notes on the mpeg properties of future captures. I do believe that if I looked correctly when I was trying to figure this out, all the settings fell within the template
Here are the helpful posts by the folks over at the other forum
http://forum.digital-digest.com/showthread.php?t=55618
thanks for looking. Taelon has really help me understand quite a bit up to this point both from his replies to my posts and his posts in general. His is the post that pointed out DVD Workshop's preference to re encode.
thanks,
thanks,
I read the link you provided, and unfortunately those folks do not understand how DVD Workshop 2.x works.
If you have compliant files for a DVD, then DVD WS 2.x's default is to NOT convert them again.
In the EDIT step, there are tabs for Video and Audio. Under those tabs is an option to "Convert to disc Template" -- if that option is open and user-selectable, then your source videos are compliant for the disc you are trying to create -- therefore, no re-encoding is needed (DVD Build process should go by very quickly). If that option is ghosted, then DVD WS does not believe your source videos are compliant, and will convert to the settings in your project template (taking a while to convert)
George
DiscCoasterPro
Forgive my ignorance, let me just be sure on this. If the option is available to be checked ... BUT IT IS NOT CHECKED .. then DVD Workshop will not re-encode files that are deemed compliant by falling into compliant parameters.
If however the option is available and IT IS checked, then DVD Workshop will convert files that .. .although compliant, do not actually "exact" the specific settings.
Is that accurate?
**edit** one last question (hehe for now)
Will that checkbox change in the edit mode for each title that is currently highlighted if some titles are compliant and some are not?
sorry George ..I'm trying
Is that accurate?
Forgive my ignorance, let me just be sure on this. If the option is available to be checked ... BUT IT IS NOT CHECKED .. then DVD Workshop will not re-encode files that are deemed compliant by falling into compliant parameters. Correct
If however the option is available and IT IS checked, then DVD Workshop will convert files that .. .although compliant, do not actually "exact" the specific settings. Correct -- it will convert the videos to your project settings
Will that checkbox change in the edit mode for each title that is currently highlighted if some titles are compliant and some are not? Yes. It is for each Video Title.
George
DiscCoasterPro
mikej
I'm also having problems with 'compliance'.
I am importing MPEG2 files created in ProCoder Express (for Edius), and would expect them to be compliant. However, the DWS 'convert to disc template' option is greyed out so I assume DWS does not seem the files as compliant. It then converts them before burning the disc, but I end up with poor image quality.
Perhaps I'm getting something wrong in ProCoder, but I've tried its preset templates and also custom setups and the settings seem to make sense.
Any suggestions very much appreciated.
I don't know ProCoder, but are you sure you are creating mpg files that are DVD compliant in the same format as your WS2 project settings? This is important.
mikej
Thanks for the reply. Possibly the case that some settings are different - though I can't immediately think where. I'll go back and have another look.
Out of circulation for a week now so if I don't post that's why, but if I do eventually find this to be the issue I will post again in the hope that others might benefit from my learning curve!
