Hello everyone......I recently captured some film (panisonic handicam) using my video capture in media pro 6.5, and then burned into a dvd using movie factory 2.0.
The problem is there is a lot of flickering in the finished DVD. I captured at 720x480 and 6000 kpps. What am I doing wrong this is my 2nd attempt to record this film.
Thanks for all the help, Jim
flickering in dvd
Cuppa T
jamcrky, I hope someone will be able to answer this question as I posted a similar one on Jan7, 80 people have looked at it, but that is all no help.
I wanted to make sure at least you get an answer even though it might not help. I have contacted Ulead twice. I received one answer that wasn't any help.
All the best to you.
jamcrky
flickering
I know the camcorder is simply a analog tape, not digital. I dont what the settings where, but can you tell me what they should be, and then I can compare them to see if set right.....
really apprec your time and help Jim
jamcrky
thanks PHd
I am using a ati 7500 radeon video card....this is an area that always confusing me and i wish I had more specific info for you....I am using the video capture software in MPS 6.5. I have use the software from the ATI card to record video would this be more effective....thanks and remember patience is a virtue PHD
lwolff123
maddrummer3301
If your using the ATI all in wonder card that can capture analog
video then use the following settings to capture a direct
Mpg2 dvd compliant file.
Format = Mpg
Format = Mpeg2 - DVD
De-interlacing options = Encode Interlaced
Audo Format = 48khz 16 bit Stereo
Standard NTSC
Resolution = 720 x 480
(Next Screen)
P Frames = 4
B Frames = 2
Closed GOP's = Yes (checked)
(Next Screen)
Variable Bit Rate = Yes
Max Bit Rate 8000kbs - 9000kbs (I use 9500kbs)
Target Bit Rate = 6000kbs - 7000kbs
Motion Estimation Quality = 80+ , Try 100%, if drop frames then lower the setting.
Audio Encoding 224kbs - 256kbs
Use the "One Touch Record" Icon to set the capture directory.
MD
Format = Mpg
Standard NTSC
(Next Screen)
P Frames = 4
B Frames = 2
(Next Screen)
MD
