how to change the settings in moviefactory 2?
numerodix
Post by numerodix »
Ok I have an unusual problem. My grandfather is really into making films (hobby thing) and among other software, he uses MovieFactory a lot, version 2 to be precise. But he's not terribly advanced in computers, so at times he struggles with simple problems. Now, I don't use the software and I've never even seen it but I need to find out how I change the setting for where the temp files are written (I'm guessing the iso image) before it's burnt to dvd. Evidently, the default setting is on c: somewhere, and his drive is full, so he needs to write them some place else.
Can someone tell me how to change the location of the tempdir/scratchdisk in MovieFactory 2?
rwernyei
Post by rwernyei »
To do this open up DVDMF and select DVD and click next. Now you will see 2 buttons on bottom left-hand side of the screen. Click on the button that has 3 bullets and lines on it. Go to Preferences and click on it. You will be at the General column and on the bottom is Working folder. This is what you wanted.
*Note:
The working folder will consist of 4 separate folders. One for your images used for menus, the burn temp folders, convert folder for any trimmed clips and Ulead DVDMF folder. There is also a separate capture folder that one can change the location of on the capture video page.
numerodix
Post by numerodix »
Ok, I'll try that. Thanks a lot!!
