Are multiple textures possible?
rafalk
Since you can assign video as texture to an object such as CUBE, would it be possible to assign different textures to each face of the cube? I haven't been able to figure it out and the help file doesn't help much.
Sure you can. One can assign an image or video to any side of your object, different images or videos on separate faces or the same one image or video on the whole. On the top you will see the cube with all different faces(top, bottom, sides, etc...), this is the face toolbar. This is where you can enable any number of faces 1-all for your object and assign a texture to it. Hope this helps.
