Error message when burning a DVD-R
glenburg
Post by glenburg »
I am an encountering an error message when burning a DVD-R. My video clips were recorded on a Pioneer DVD recorder and then successfully converted from a DVD-RW to a DVD-R on my PC using this software and my AOpen AUW 1616 AR DVD burner. I then successfully re-edited the clips to burn on to the DVD-R.
After I select Burn, it prepares data and begins converting the video titles.
When the total progress reaches, 3% for preparing title data and 39% for converting video titles...2/5, I receive the following message:
Ulead MovieFactory has encountered a problem and needs to close. We're sorry for the inconvenience. It give the choice to Debug or Close. Either one I chose, closes the file.
The error signature is:
AppName: dvdmf.exe AppVer: 4.0.0.0
ModName: ulmpgtransax
ModVer: 1.0.0.27 Offset: 0000c5fd
I checked the properties for the five video clips and they are identical. The properties are:
24 bit 720 x 480
29.97 fps
DVD-NTSC 4.3
Video data rate -
Variable mix: 7000 kps.
Audio data rate: 256 kps
Dolby Digital Audio: 48 khz, 2/0 (L.R)
ploggy
Post by ploggy »
open the project setting and uncheck the "do not convert compliant..."
Click the Change mPEG settings and select Customize. Match the video properties and the project setting then click OK.
see if this works
Who? Me?
glenburg
Post by glenburg »
Thanks. I will try it.
