OK, I give. How do you do simple video fade ins and outs?
jebrighton
I am testing V9 and like what I see so far except one thing. On other editors, this is a gimmie but I cannot find it on V9. I simply want to start with black and fade in to my video. I also want to fade out to black sometimes as well. I found a third party plug-in to fade out to black. What gives? This is simple stuff. I cannot find anything in the program that allows me to fade to anything except titles.
THoff
jebrighton
Ted Hyatt
How about VS7 X-Fade
Can't find it anywhere, even in downloads?
Is there any way to fade IN to a clip or project?
rdenny
Re: How about VS7 X-Fade
What version of VS are you using.Ted Hyatt wrote:Can't find it anywhere, even in downloads?
V8 trial did not have the X-Fade
Using VS 9 and 8 i see 20 transitions in the F/X library.
Trevor
Although we refer to add a black colour clip, you can use any colour.rdenny wrote:Doesn't the fade to black transition fade to black then fade up the next clip? I am 99% sure I used this and discovered (in VS9) that there is no need to insert black and use 2 crossfades.
Whereas the fade to black is just that, black.
Trevor
rdenny
OK, so if you want to fade to something other than black, then fade into the next clip, you use 2 crossfades surrounding an inserted color-clip of the desired color. If you want fade to black then fade into next clip, you use 1 fade to black transition between clips. 1 transition instead of 2, and no inserted color clip.trevor andrew wrote:Although we refer to add a black colour clip, you can use any colour. Whereas the fade to black is just that, black.
Trevor
Bob
THoff
Re: X-Fade
The Full version of UVS 7 has it, but SE versions may not. I recommend you download the Burger Transitions, they include a Crossfade transition.Ted Hyatt wrote:X-Fade doesn't seem available in VS7.
