Rendering MF4 AVI to MPEG2 - CPU utilisation only 50%?
ruggy1
Post by ruggy1 »
Just bought a new computer, transfered all Ulead programs over, but when I am rendering, the Task Manager only shows CPU utilisation of 50% max. I have 3.2GHz P4 with a Gigabyte motherboard. Anyone else have the same issue? Thanks
jcc
Post by jcc »
Don't think that you have an issue. Your CPU only needs to devote half of it's capabilities to run DVDMF.
DVDDoug
Moderator
Post by DVDDoug »
Actually, it does seem a bit strange that MF is not utilizing 100 percent of your CPU's cycles.
I can think of a couple of possibilities:
- Your hard drive is the limiting factor. The CPUis idle while waiting for the hard drive.
- Ulead did something to the program so that it doesn't "hog" the CPU. This seems unlikely, because Windows will allocate run-time to each open application... It won't allow a regular "user mode" program to hog the CPU. (A driver can take-over the CPU and not allow other programs to interrupt.)
ruggy1
Post by ruggy1 »
Thanks guys. I did a test render, and even though the CPU showed 50% max it did outperform my old 2.8GHz P4 by 14% - exactly as expected. It is as if Task Manager is expecting a dual core system, but this isn't one. So I will live with 50% knowing that it is actually 100%. Thanks
