Capturing via tv-tuner help
brharris
Post by brharris »
I want to use VideoStudio 9 to capture video from my tv-tuner card, the MSI Theater 550 pro, to my hard drive. Trouble is, I am plugging into the composite port of the tv-tuner and VideoStudio only wants to capture cable TV. I have my cable connected to the card as well (in a different port), and videostudio gives me the option of which channel want to capture from. So basically, i see no way to toggle videostudio to take the input from my composite port rather than my cable port. Anyone know how? An additional question, my capture card has a hardware mpeg-2 encoder on it, can I get videostudio to use that capability when I do capture?
Thanks,
Brian
michaeltee
motherboard: HP 82F1
processor: Intel Core I5 7400 3 GHz
ram: 16 GB DC
Video Card: Intel HD Graphics 630
Hard_Drive_Capacity: 2TB Hybrid
Monitor/Display Make & Model: Samsung S24D300
Corel programs: Installed: PS Pro 2021, VS Ultimate 2020
Post by michaeltee »
Most TV Tuner devices designate a channel number for your S-Video and Composite inputs, for example Composite = Channel 200 and S-Video = Channel 210. This would allow a capture utility to "see" those inputs as "cable" channels. Usually you can customize these properties from your card's tuner setup UI.
-Mike
KiwiJock
Post by KiwiJock »
Not sure if I am missing the point but I am doing the same thing.
Capturing using MPEG format, under options/video and audio capture property settings/source tab/video input source and there is a choice of video tuner, video composite and video s-video.
Tuner should give you tv, which is what I get, assuming this will be your cable and i use composite to collect from VHS video player, haven't tried S-video
hope this helps
cheers
kiwijock
brharris
Post by brharris »
ah, it was I, not you who was missing the point. thanks. but do you think this program will take advantage of the hardware mpeg2 encoder found on my capture card?
KiwiJock
Post by KiwiJock »
glad it worked, I capture to MPEG through my card, so would think you should be able to as well. Need to have reasonably good processor and RAM to collect and convert at same time. My old pc was Athlon 1.6 with 512 RAM and couldn't cope, got a new one with P4 3GHz and 512MB, worked fine but have just doubled RAM to make sure.
KiwiJock
Post by KiwiJock »
KiwiJock
Post by KiwiJock »
apologies for double post, guess I shouldn't use the back button and refresh!!
