I am using a Brand New HP Compaq DC7600 computer with a 3 ghz CPU and plenty of Ram.
When I render off a TGA sequence it is only processing approx an 8th of each frame. I have all the options turned to optimal in Cool 3D, the animation is Pal and 375 frames. Is this a Hardware problem as the sequence renders fine on our other workstation. Any help would be greatly appreciated.
Cheers
Urgent Help, Bad Renders
JASE,
I looked at the specs of the HP Compaq DC7600 on the web. All the bundled systems I saw had integrated onboard graphics. This was the primary graphics adapter. But there is an open PCI Express x16 slot. I would buy a new graphics card and disable the onboard graphics in the BIOS. Other than that, the specs look good for that model.
