I need to create a CVCD
nievas
Post by nievas »
Hello
I need to capture about 2 hours from VHS in 1 CD (700MB) How can I change audio and video bitrate in Moviefactory to make only 1 VCD (CVCD) ?
thank you
shspvr
Post by shspvr »
CVCD I never heard of that one and I don't you going get 2 hour one CD disc and can that going like look like crap.
You be better off building DVD disc and pump up the rez and bitrate for better PQ.
nievas
Post by nievas »
Here is an automatic translation
CVCD (Compressed VideoCD)
the CVCD is a format that exclusively we developed in VCDSpain looking for the Maximum quality possible in the smaller space, having like limit 1 single CD.
The limits are established by the configuration but it is possible to store up to 130 minutes of video by CDR74 (much more if we increased the size of the CD or reduced limits of the acceptable quality) the CVCD is made in Mpeg1 or Mpeg2, to a resolution of screen of 352 xs 288, 25 Frames per Second, with Variable resolutions from 0 to 1,150 (it settles down a Maxima resolution and a minim between those values) and it bitreats Constant for the audio one between 96 Kbs and 224 44,100 Kbs to kHZ. The CVCD we will find it in called MPEG1: CVCD like VCD Standard Non. And we will find it in called MPEG2: CVCD like SVCD. The CVCD as VCD Standard Non allows to Responsibility of Menus of simple level (a single screen) or multiple level (several screens). It does not allow but of 1 audio nor seleccionables subtitles. The CVCD as SVCD allows to Responsibility of Menus of simple level (a single screen) or multiple level (several screens) and but of 1 audio selectionable one. The CVCD is not an Official format therefore we will not find in the manuals of the reproducers, compatibility with this format. Whereupon a reproductive support VideoCD and/or SVCD it is generally sufficient to guess its compatibility but it is not possible knowledge it with exactitude, for that we have in the general forum sections destined to ask on models of readers and compatibilities. There is practically a 90% of reproducers of DVD with support for CVCD, % in increase according to leave new reproducers to the market since all the models that are leaving usually are compatible.
