VS 7 analog capture problems with ATI ALl in WOnder
tattooed_vinny
Hoping someone can help me on this. Am using a ATI All in Wonder 7500 video capture card via the analog input to do a buddys wedding video. I Am getting nothing, neither video nor sound on either the s video or component inputs. My firewire card works with vs7 fine, byt have to use the analog for the video i was given. Have re installed the service packs, the catalyst update and tried everthing i can think of and am aboot to just do this video on my vcr. Any help or suggestions would be greatly appreciated. Thanks Vinny
Telgaladhion_Greyskye
Check if your ATI's driver is listed, and not conflicting with other devices. I think you could update it by downloading the latest driver from ATI's site.
You could manually enable the capture plug-in: use Ulead DirectShow Capture Driver or Ulead VFW Capture Plug-in if you want to capture in AVI format, or Ulead DSW MPEG Capture Plug-in when you want to capture in MPEG.
Also check out the "Announcement:" thread. It'll help you a lot.
When you go to the capture screen, does VS recognise your capture card.
Do you see ATI Rage Theatre or something like in the ‘Source Box’
I assume this card has a tv tuner. Connect an antenna, Can you see the tv program?
Select ‘Options’—Video capture properties….
Is the input source set to 'tuner'
Change input source to ‘Composite’
The audio may need a connection from the capture card to ‘line-in’ on your pc.
Check your card manual.
Trevor
Trevor
