VS 9 need to pay to indeo to use tha sample videos ?¿?
jcolo
Post by jcolo »
I get the following message while trying to visualize the sample videos that come with VS9.... and in the indeo page says I have to pay for the codecs....
is there an mpg version of those videos. ?¿?¿... I am blunt stupid and I am missing something ?¿?¿
The program you are trying to run requires a current Indeo codec.
To obtain a current driver that is compatible with this version of Windows, please contact the manufacturer at http://indeo.ligos.com.
Thanks.
JCG
Post by Trevor Andrew »
The indeo codec file is part of the VS 9 installation disc.
Auto run the install shield and select 'Install Utilities'
Select indeo.
Trevor
jcolo
Post by jcolo »
I have the downloaded version of VS9 (upgrade from VS7) ... and unless mistaken I have installed all the packages that I downloaded...
ddr21_(E)_FORUVS9.EXE
dvdmenubonuspack.exe
full spectrum 22k.exe
uvs9_contentpack_part1/2/3/4.exe
uvs_upg_na_e_rtm.exe
Any other hints.... ?¿?
Many thanks for your help.
JCG
Extract from ulead FAQ's
http://www.ulead.com/tech/vs/vs80faq.htm
I am having problems viewing the Library video files. Is there a driver that I am missing?
The Indeo driver is required to play the Library video files. Some computers may not have this driver pre-installed. Ulead has provided the Indeo driver on the installation CD. Please insert the CD into your drive. A splash screen will appear. Select the 2nd option: "Install Utilities". Click on the "Indeo" option to start the automatic install.
Trevor
Cauptain
Post by Cauptain »
Hello jcolo,
Man it very easy solution.
go to: http://www.free-codecs.com/download/K_L ... c_Pack.htm
Download and install all (mark Indeo codecs hehehe).
For all user for UVS or another soft.
It´s a very necessary codecs soft.
Try and talk about later ok??
Cauptain
THoff
Post by THoff »
Oh please, do NOT install ANY codec packs, they cause far more problems than they solve.
If you need one particular codec, by all means, download and install it, but do not download a bunch of often conflicting codecs pulled together by some guy and wrapped in a single install script. You have been warned...
Indeo Codec Download Page
jcolo
Post by jcolo »
uhmmmm you are putting me between a sword and a hard place....
I need you both to cut in a deal for me. I just need the indeo thing.... and I am alergic to trouble...
any other choices ?¿
Cheers.
JCG
Go with THoff
Trevor
bop
Post by bop »
Go with THoff
Brian
jcolo
Post by jcolo »
It did work. Thanks. Thoff and company.
JCG
