ULead Photo Express 4.0 Issues -- HELP!
TLM89
Post by TLM89 »
I recently downloaded 4.0 (I have XP) and have not been able to get it to work. When trying to aquire an image from my HP scanner, I get a TWAIN error. I dowloaded the drivers, checked the cables and tried again. This time I get a pop up which says the server is busy (not online, no other applications running) and asks me to retry or switch to the busy application - which I have NO idea what it is. I hit retry and nothing happens which makes me have to restart my PC - freezes everything. I pretty much go back and fourth between the TWAIN message and the other. Really irriatating to say the least. Anyone else been through this? :!: :?:
pasky
Post by pasky »
hello there!
Let me share some workaround regarding your problem.
When using Photo Express to acquire an image, make sure that your TWAIN driver, (provided by the scanner vendor), is correctly installed. This TWAIN driver sends the acquire command from the application to the scanner and processes scan data from the scanner and passes it to the application. You need to select the data source before starting the scanning process and there may be more than one device attached to your computer, so you need to specify which one to use. These steps will help you get started.
1. Check if the scanner power switch is on.
2. Check if there are any loose connections between your computer and the scanner. Try scanning again.
3. Check if your scanner's model name is on the data source list. If not, install the TWAIN driver for your OS and then check again if it was installed correctly. (If you still can't find your scanner's model name, please contact your scanner vendor for more information on how to correctly install the TWAIN driver for your OS.)
4. Click Scanner on the Toolbar, and in the Options Panel, select the scanner from the data source list.
5. Specify the destination for the acquired image, calibration scheme to apply, and select the post processing options to apply in acquiring.
6. Click Acquire to start scanning.
G :lol: :shock: D LUCK!
madmega
Post by madmega »
I have the problem that i never ever installed that program before, but i wanted to try the trial version, when i started it, it directly says that the trial period has ended...
Wizentub
Re: ULead Photo Express 4.0 Issues -- HELP!
Post by Wizentub »
TLM89 wrote:I recently downloaded 4.0 (I have XP) and have not been able to get it to work. When trying to aquire an image from my HP scanner, I get a TWAIN error. I dowloaded the drivers, checked the cables and tried again. This time I get a pop up which says the server is busy (not online, no other applications running) and asks me to retry or switch to the busy application - which I have NO idea what it is. I hit retry and nothing happens which makes me have to restart my PC - freezes everything. I pretty much go back and fourth between the TWAIN message and the other. Really irriatating to say the least. Anyone else been through this? :!: :?:
Perhaps your spare ports are blocked at the moment.
