sometimes, when i try to modify some text to my *.ufo projects (also for any other *.ufo project...) the program crashes, particularly when i select/cut/add words or letters to the text. I've reinstalled the program few weeks ago, for same problem, but infortunately the problem don't disappear.
tanks!
liftman www.moredifficult.org
PI 10 crashes when modify text
2log
re: PI 10 crashes when modify text
When you install a software, the installer extracts temporary files needed for the installation on a temp folder. These folders are usually:
C:\Windows\Temp
C:\Documents and Settings\[User Name]\Local Settings\Temp
If the temp folder holds old installer files that may be corrupted or are duplicates with the same filename but are used for a different software, it could cause a problem for your new installation of the software. Before you reinstall the software, make sure to clean the Temp folders.
The Local Settings folder is a hidden folder so you have to enable Windows Explorer to see hidden files and folders. Open Windows Explorer, go to Tools > Folder Options > View and check show hidden files and folders. You can now open the Temp folder from the Documents and Settings folder and delete the files there before you make a new install.
C:\Windows\Temp
