Videostudio 9 Query
PhilCCFC
Videostudio 9 Query
Post by PhilCCFC »
I have just bought and installed VS9, I'm having a play around with the software capturing some DV footage and all appears well until I get to around 3.5 minutes through the capture and the system stops capturing and comes back with an error message saying something about a lack of hard disk space...thing is I have 145Gb of free space, surely it doesn't need more than that - does it? :shock:
Help!
Post by Trevor Andrew »
What is your computers filing system
Fat 32
Or
Ntfs
If its Fat 32 then there is a 4Gb limit for individual files.
Using Ntfs there is no limit except your hard drive space.
If you are capturing to uncompressed Avi you will use about 65 Gb per hour.
How are you capturing your video?
Do you have a Digital Camera.?
Do you have Firewire?
The figures you have given look as though you are capturing to raw uncompressed Avi on a Fat filing system.
Trevor
PhilCCFC
Post by PhilCCFC »
FAT32 for the drive, using XP.
I have connected my video (JVC-DVL100) via the S-Video port on an ATI card.
EDIT; Just reading through some settings and the compression under one of the properties is YUY2.
Changed the format to DVD and it's gone passed the 3.5 minute mark! Will see if it captures ok...thanks.
Ok
At least we know why.
I think it would be best to convert your drive to Ntfs, I don’t know whats involved, others on the forum will give you some guidance if you need it.( I don’t think its difficult ).
For the time being, you can either capture to Avi or Mpeg.(dvd)
Avi
Select –Avi- from the ‘Format’ box
Options
Video and audio property ……….
Tick ‘Use software compression’
Advanced
Select ‘Microsoft Video 1’
This should capture at 13 Gb per hour, you should get about 20 minutes / 4Gb
Mpeg
Select –Dvd- from the ‘Format’ box
This will select the standard pal template.
Check the settings in options.
This should capture about 4.3 Gb per hour.
DV-Avi is the format that a digital camcorder records in.
This can be captured/copied to VS using a Firewire connection, This is the best method to get your data to your pc.
Read the top posting re:- recommended procedure.
Read the various tutorials.
Trevor
PhilCCFC
Post by PhilCCFC »
Thanks Trevor
tyamada
Post by tyamada »
You should really convert your drives to NTFS, manages your files better than FAT 32 and you can capture video files that are gigabytes in size.
I have captured HD video that is over 8 Gig.
To convert a volume to NTFS from the command prompt
Open the Command Prompt window.
In the command prompt window, type
convert drive_letter: /fs:ntfs
For example, typing convert D: /fs:ntfs would format drive D: with the ntfs format.
