Hello
I'm building a DVD with a 23 minute "movie", which has two audio tracks (original and commentary), but I'm having a problem with the 2nd track.
At the "finish" stage, all is well, but on the burned discs, only 20 seconds of my commentary track are present - after 20 seconds, it starts over and keeps repeating the same 20 seconds over and over.
I am using the trial version, and I've read the restrictions on the trial version, and "only 20 seconds of audio on secondary tracks" is not one of them.
If I can't get this working, I'm certainly not buying this program!
Help!!!
Incomplete burning of 2nd audio track
htchien
Is the second audio track an MP3 file? If it is, I think to convert it to WAV before you use it in DVDWS might help.
Hope this helps.
H.T.
Hope this helps.
H.T.
Ted (H.T.)
speedyrb
speedyrb
I was able to fix it by checking the "convert to disc template" box. Since I had set the disc template to "LPCM", it converted the file from MPEG-Audio to LPCM, and this did the trick. (Since I'm using the trial version, I can't import or convert files to AC3/Dolby Digital, but that's one feature of the full version that I'm really looking forward to!)
Thanks!
Thanks!
