Importing MF3 to MF4
Dancingbear
Post by Dancingbear »
I have been using MF3 for sometime and have a number of projects. I have now finally upgraded to MF4 and want to now if I can import my old projects? I can find anything obvious in the User manual pdf. What happened to good old fashioned help files called from withing the program.
Also I understand that once MF4 upgrade has been installed I can uninstall MF3. Is this true?
Simon
AnimeChick
Post by AnimeChick »
Ulead programs are usually backwards compatible. So you should be able to open the project files from version 3 in version 4.
You should be able to unistall the previous versions. Upgrades only require them to install.
Dancingbear
Okay, I am an idiot and was tring to import the wrong file. Now that's cleared up I have another problem.
Following on from other advise I uninstalled MF3. Now when I try to run MF4 I get the error
DVDMF
A Key Error
Can anyone explain this?
Ta
Simon
