Make layers with topography effect.
sheng-si
motherboard: Hp motherb
processor: amd
ram: 32 Gb
Hard_Drive_Capacity: 1 tb
Monitor/Display Make & Model: ASUS VG24VQR
Corel programs: paintshop pro Videostudio 2022
Post by sheng-si »
Searching for possibility to make seperate layers while using the topography effect.
Then you can with a cutting machine make for instance a 3d portrait from someone.
I found this info, but topography is a standard effect in PSP.
But if there is a script maybe possible to change that script
https://help.corel.com/paintshop-pro/v2 ... raphy.html
Admin FB Paintshop Pro NLD for dutch users.
Radim
ram: 4GB
Monitor/Display Make & Model: 27 inch
Re: Make layers with topography effect.
Post by Radim »
I think for that cutting.. are some better specific programs more suitable than PSP.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
Most cutters come with software that can use vectors or can convert B&W images into paths. PSP would be used to create the B&W images. However, the topography effect creates overlapping shapes based on colors in the image and doesn't return the layers. So there's no good way to separate the blobs into separate images that can be stacked after cutting.
