hi..
How do I make maps in Paintsho for
1. color map?
2. normal map?
3. Golss map?
4. displacement map?
Like you can do in Photoshop..I mean maps as shown in the attached video:
https://www.youtube.com/watch?v=DowzpfNFKVY
Thanks and all the best
hi-ask abaut map
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: hi-ask abaut map
Photoshop has those filters because it used to support 3D models in the editor. PSP doesn't. There is a plugin for this that can work with PSP though I've never used it nor do I truly know anything about it. I found this old article on it though - https://developer.valvesoftware.com/wik ... t_Shop_Pro
There are also free editors that can do this, I don't know for sure but it's possible you can do it with Blender.
I have version 10 that I haven't used in a while.
1. With which filter can it be done there?
2. Why download commands from newer versions?
- ram: 6 GB
I don't know what you're asking.
As I stated, PaintShop Pro (all versions) have Zero 3D material map creatings. If you want to use PaintShop Pro you need to use a plugin as outlined in the article I pasted above. If you're saying you have Photoshop version 10, then the video you posted might have what you need. If not, then it's from before those commands.
I don't know what you mean by "why download commands from newer versions?" You can't download commands from newer versions.
EDIT:
I was recently reminded of AwesomeBump - it's a generator for textures. It can create all of the maps you wanted, and gives a demo of them being applied to a 3D object as you edit and play around.
https://github.com/kmkolasinski/Awesome ... Winx32v5.1
EDIT:
