VideoStudio crashes while loading 4k mp4 file
Antois
processor: Intel i7-6700 X64 processor
Video Card: Intel HD Graphics 530 8GB
Hard_Drive_Capacity: 2x 240 GB
Monitor/Display Make & Model: Samsung S60UA (HDMI)
Corel programs: Video Studio 2022
Post by Antois »
I am trying to edit a 4k mp4 file in VideoStudio 2022 however as soon as I put the file on the timeline, the programme immediately closes.
The file is 3840x2160 / 25 fps / approx 18000 kbps. The file is shorter than 50 seconds.
By default, can VideoStudio 2022 not handle such high resolution and high bit rate?
Or is something going wrong that really shouldn't go wrong?
RobertOZ
Hard_Drive_Capacity: 7 TB
Re: VideoStudio crashes while loading 4k mp4 file
Post by RobertOZ »
VS2022 has no issue with 3840x2160 25fps, not sure about the 18000 kbps though, would need to find 4K 18000kbps mp4 files to test
Antois
Post by Antois »
Well, VS2022 has an issue in my case. A second file same properties but with a bitrate of 10000 kbps closes the program as soon as I put it on the timeline. I have not a very fast computer however I do not expect that my computer is the cause of Corel VideoStudio 2022 not able handling 4k files at all.
Are you able to share one of your video files, then we can try on our setups.
What device was used to record the videos?
Antois
Post by Antois »
https://vimeo.com/842300831
It's a video at vimeo.com
Antois
Post by Antois »
I downscaled this video from 4k to HD . The HD file is accepted by VideoStudio 2022 however as soon as I try to edit this file at the timeline after a few seconds VideoStudio crashes. I had this several times also with another downscaled video.
canuck
operating_system: Windows 8.1
Post by canuck »
Downloaded the file from Vimeo. Had no problem loading into VS 2022 and doing edits.
This is of course a different file from the file you are having problems with in your initial post. The Vimeo file is over 4 minutes while you state your problem file is 50 seconds.
This creates confusion.
Antois
Post by Antois »
Thanks for testing this video!
I used some parts from this video which I splitted with SolveigMM Videosplitter.
Perhaps this changes the video in such a way that VideoStudio can no longer handle it
Alipod
motherboard: Aorus Master X570
processor: AMD Ryzen 3700X
ram: 32GB 3200
Video Card: Sapphire Nitro+ AMD RX 5700 XT 8GB
sound_card: Realtic
Hard_Drive_Capacity: 4TB NVMe SSD
Monitor/Display Make & Model: AGON 2K
Corel programs: VideoStudio Ultimate 2023
Post by Alipod »
if I'm correct, your video file is 10-bit
VS2023 and previous versions only support 8-bit
check your file using mediainfo
