Moving a layer that's not the top layer
df
ram: 64gb
Hard_Drive_Capacity: 1 Tb
Post by df »
Sorry if this has been answered elsewhere, searching didn't really yield any results. I'm using PSP 2019. I'm constantly finding myself needing to move a layer with the Move Tool (alternate to Pick Tool). When I use this tool it will default the layer selected to the top layer, this is very frustrating. Is there any way to not have this happen? I have a color layer or a lighten layer on top and the camera has moved slightly with a previous layer. Even if I make the top layer lower opacity it still refuses to select and use the lower layer no matter what I try. Is there a trick? Does the latest version have auto align layers yet?
The manual is pretty useless for this, doesn't even give the caveat that the layer to be moved needs to be the top layer.
Regards, Dan
Forriner
motherboard: ASUS Z170M-PLUS
processor: Intel Core i5-6400
ram: 16 GB
Hard_Drive_Capacity: 1250 GB
Monitor/Display Make & Model: Philips Brilliance 272b 2560 × 1440
Corel programs: PSP 2023
Re: Moving a layer that's not the top layer
Post by Forriner »
Have you tried activating the layer you want to move on the Layers palette, and holding down the Shift key while dragging the layer?
Normally the Move tool activates and moves the first layer with a non-transparent pixel under the cursor, in your case the top layer. The Shift key makes it use the active layer.
df
ram: 64gb
Post by df »
That's it. Thank you. I could have swore I did try that earlier but apparently I imagined it. Thanks so much.
Regards, Dan
