Hello, I've a combo printer/scanner from Brother model DCP-L2520DW, when I look on :
File -> Import -> TWAIN Acquire, I get a window with message : No scanner found !
How to setup my Scanner to use it with PSP
Thanks.
Vincent.
See if using WIA will work. File -> Import -> From scanner or camera
There are a few recent topics on this very problem and the answer is the same. The drivers are the "problem". 32-bit PSP can only load 32-bit drivers. 64-bit PSP can only load 64-bit drivers. If your scanner's driver is 32-bit your 64-bit PSP cannot read it with TWAIN. If your scanner has 64-bit drivers then 32-bit PSP cannot see it
However on recent versions of Windows the WIA protocol can talk between program domains provided your scanner has a WIA driver.
Thanks to all, I try with File -> Import -> From Scanner or Camera and it work!
Understood from X32 or X64 no compatibility, TWAIN is an oldest method, using Import from Scanner work that's the goal !
Thanks again.
