Problem applying masks if clip has been zoomed
tringoldsby
processor: Intel i7-8700K
ram: 32GB
Video Card: Radeo RX 5500 XT
Hard_Drive_Capacity: 1 GB
Monitor/Display Make & Model: Asus
Corel programs: CorelDraw, PaintShop Pro, VideoStudio
Post by tringoldsby »
In VideoStudio 2023 it is possible to zoom in on a video and also possible to create video masks. However, if you first zoom on the video, and then attempt to create a video mask, the Mask Creator operates on the unzoomed video. This means that, when you exit from Mask Creator, the mask is not properly aligned on the zoomed video. Even if you split the original video into the unzoomed and zoomed portions, and run Mask Creator on the zoomed segment, it *still* operates on the original unzoomed video. This is a bug for which I have not found a workaround.
