I have psp 2019 Pro, and 2022 Pro.
I'd like to know if there is a way to use the same workspace in my psp 2022 as in my psp 2019.
I have 2019 set exactly as I want it, and would love to use it in 2022 as well.
Is that possible?
TIA,
Leslie
Use Workspace from another version of PSP
Leslie
- processor: intel core i7
- ram: 32 gb
- Video Card: intel iris
- Hard_Drive_Capacity: 1 TB
- Monitor/Display Make & Model: Dell Inspiron 7700 27 All-in-One Desktop
- Corel programs: 2019 Ultimate, 2022 Ultimate
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: Use Workspace from another version of PSP
The best way is to just manually set it up the same way.
Technically I believe 2022 should be able to read in PSP 2019 workspaces but it's not advisable as there can be subtle differences between the two and PSP goes all funky if something doesn't quite match expectation. So it may work for a short while and then need to be reset when you notice something isn't working quite right.
Also any new commands in the menus will be removed because they didn't exist in the older version. So if you want those you have to add them back in.
So it's easier to take the time to set up your workflow when you get your new version of PSP, and save out a copy of the workspace for use only with that version of PSP.
Leslie
- ram: 32 gb
Thanks for your advice.
The last thing I need is a wonky psp!
