Good day,
I have been using Corel VideoStudio 2022 Ultimate, and recently upgraded. Now, the 3D Title Editor seems to be completely without functionality. It is simply impossible to use. I was using it in the 2022 Ultimate Version without any issue. Has any code changed?
3D Title Editor Defects
- CalayuganKings
- motherboard: ASUS PRIME B560M-A
- processor: Intel
- ram: 32 GB
- Video Card: NVIDIA GE Force RTX 2060
- sound_card: NVIDIA GE Force RTX 2060
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: Samsung S32A8
- Corel programs: VideoStudio 2023 Ultimate
Re: 3D Title Editor Defects
First I have just tried T3D using 2023 with no apparent issues.
Yes the T3D version from 2022 to 2023 has been updated from 1.0.10.307 to 1.0.10.317, viewing the installation files properties (64bit\Common\Setup\RunTime)
Does your VS version 2022 T3D still work ok as that version will be using the same T3D as 2023
Installed here:-
C:\Program Files\Corel\VideoStudio 3D Title Editor
Installed here:-
- CalayuganKings
- processor: Intel
- ram: 32 GB
Thanks for the reply. The T3D editor (main button ribbon) seems to recover after I restart Visual Studio 2023 Ultimate. Before that, I delete everything possible in the %TEMP% folder. Still, the 3D titles listed as "presets" in the "T" (main side menu) show some quirky editing behavior.
If I use, for example, the preset "3D Title 1" from the side menu (i.e. the "T" button, just after A/B transitions), the resultant editing experience is quirky. If I drop a preset "3D Title 1" onto the overlay track, and double-click it, it does execute the 3D Title editor. But that experience is just quirky. Delays, hanging, memory leaks (task manager see memory usage crawl up), and so on. Anyway, I just restart ad remove the %TEMP% items, and there is some stabilization.
- CalayuganKings
- processor: Intel
- ram: 32 GB
Re: 3D Title Editor Defects - VS 2023 Ultimate
Hello Trevor and other participants. I completely cleared and reinstalled VS 2023 Ultimate. The 3D Title Editor (T3D) is not behaving the same way as 2022. For example, the text values are not updating properly. Any edits in the text attribute field at the right hand side of the 3D Editor Application does not capture the font immediately, and does not refresh. It is for sure defective. I can call support on this, but I believe that the version change created breaking changes.
- CalayuganKings
- processor: Intel
- ram: 32 GB
Hi, after starting on testing a completely new small "template" that I reuse, the T3D Editor seems to be fully functional. There may be a possibility that larger projects have issues.
