Audio editing remains a problem with VideoStudio. I'll keep reporting it until they wake up.
Often the programme crashes precisely during audio editing
Changing fading times, something I use a lot, is cumbersome, many actions to perform
Volume changes are made properly as long as you are in project mode.
However, after rendering, the volume changes do not appear to be present in the rendered mp4 video file.
The cause appears to be the media player Gom Player. By default, audio normalisation is on there, reducing variations in volume. You can turn this off.
VideoStudio 2023 causes problems with audio editing
Antois
- processor: Intel i7-6700 X64 processor
- Video Card: Intel HD Graphics 530 8GB
- Hard_Drive_Capacity: 2x 240 GB
- Monitor/Display Make & Model: Samsung S60UA (HDMI)
- Corel programs: Video Studio 2022
- CalayuganKings
- motherboard: ASUS PRIME B560M-A
- processor: Intel
- ram: 32 GB
- Video Card: NVIDIA GE Force RTX 2060
- sound_card: NVIDIA GE Force RTX 2060
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: Samsung S32A8
- Corel programs: VideoStudio 2023 Ultimate
Re: VideoStudio 2023 causes problems with audio editing
For VS 2023 Ultimate, it seems 3D Editing has some issues too. I noticed that if I restart the product, the defects are reduced. They come back again. It appears to be some issue with the caching of the elements used in the 3D Editor. 2022 Ultimate was not showing as many defects.
Antois
Thank you for the hint to restart VideoStudio regularly
Antois
The video player Gom Player has by default an automatic volume control that amplifies the soft sounds and mutes the loud ones.
This gives you a wrong sound image that you then try to correct again in VideoStudio and when playing with Gom Player, you can't hear the correction made each time because of this automatic volume control.
You can turn off this default levelling of the audio via Control Panel > Audio > Normalizer: Off
