Ever since I upgraded to PaintShop Pro 2023, I have been unable to use the paste function.
This is not due to the question of which keys to use. Even if I copy using the drop-down menu to Copy and then attempt to Paste, all of the paste options are greyed out. Similarly, if I copy an image from an outside program and try to paste, no paste options are available.
This is also not a question of available memory. I have 32 GB of RAM and 1.7 TB of available disc space.
Has anyone else run into this probem? If so, how did you fix it?
I've been using PaintShop Pro since the 1980's (when it was shareware on old MS-DOS systems), and understand the program well, but I have never run into this problem before!
Unable To Paste
Kathy_9
- Hard_Drive_Capacity: 2TB
Re: Unable To Paste
You could try a reset as that seems to fix a multitude of issues.
https://forum.corel.com/viewtopic.php?t=67616
Re: Unable To Paste
Can we also assume that you have also tried using Ctrl+V to insert (and Ctrl+C to copy)? I have just tried that in PSP 2023, and it certainly works for me once a new space or another image is open in the PSP workspace...
Radim
- ram: 4GB
- Monitor/Display Make & Model: 27 inch
Re: Unable To Paste
Look into manual how those copying commands works. I you used some old version it perhaps changed a little bit.kjfnjy wrote: ↑Sun Oct 29, 2023 11:05 am Ever since I upgraded to PaintShop Pro 2023, I have been unable to use the paste function.
Online help PSP 2023: https://help.corel.com/paintshop-pro/v25/index.html
Cassel
- ram: 16Gb
- Corel programs: PSP 8 (JASC) to PSP 2023
Re: Unable To Paste
One very long time bug I have seen is that if you have a vector tool active, the Paste command does not work. I have no idea why but do you have a vector tool active? If so, change it to anything else (like the Move tool) and try again.
Cassel
https://scrapbookcampus.com
Radim
- ram: 4GB
Re: Unable To Paste
Realy a bug? I would expect that vector layer accepts only such objects.
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: Unable To Paste
Paste should never care about the current layer type. Only "Paste Into Selection" and "Paste as Vector Selection" have any pre-requisites. Namely, an existing selection in the image, or vector data in the clipboard respectively. The others, it doesn't matter.
Paste As New Layer - Creates a new layer
Paste As New Image - Creates a whole separate image
Paste As New Selection - Creates a floating selection that can then be promoted to a separate layer or defloated
Paste As Transparent Selection - does the same as above but removes a specific color.
None should care whether you have a vector layer, or tool selected.
- User10232023
- processor: Intel Core i7-12700
- ram: 16 GB
- Video Card: Intel UHD Graphics 770
- sound_card: Realtek ALC3246
- Hard_Drive_Capacity: SDD 512GB HDD 4TB
- Monitor/Display Make & Model: 27" Acer KA2272U
- Corel programs: PaintShop Pro 2021 (64-bit), -JASC PSP7
Re: Unable To Paste
Don't forget Ctrl+Insert and Shift+Insert to copy/paste respectively for other older users like me.
I still use those keyboard commands and both worked (for me) with PSP2021 and PSP2023 trial versions.
Windows11 might've locked the clipboard, its a known issue when win11 decides something should be copyright protected...
To test for this, restart PC, ensure no web-browswer/video/media player apps are running. Press PrintScreen button and then start PSP and try to paste.
- If pastes screenshot then win11 locked clipboard earlier.
- If it won't paste then run SFC /scannow
Alternatively use WindowsKey+V key to see clipboard manager in Windows11 and see if anything copied is there?
Radim
- ram: 4GB
Re: Unable To Paste
Windows 10/11 gets those "features" silently. Then we fight how to dissable it...User10232023 wrote: ↑Wed Nov 08, 2023 7:28 pm Windows11 might've locked the clipboard, its a known issue when win11 decides something should be copyright protected...
