please I would accept some suggestions to configure the workspace in my Surface.
Videostudio doesn't react to my screen resolution. I tried to used the Windows recomended resolution and 200% in scale, but I have problems with several secondary windows (i.e. Pan and Zoom) that are bigger than screen size.
If I use 175% scale, Visualstudio doesn't scale his fonts.
Any solution or workaround?
Best regards.
Rubén
Configuring font size in workspace
Re: Configuring font size in workspace
Welcome to the forum!
You could try this. Close VideoStudio. Then right click the desktop icon to open it again. A box should appear on screen with a number of tabs. Left click on the Compatibility tab. Down towards the bottom, click on the button labelled "Change high DPI settings". A new box should appear. Again, down near the bottom tick the box beside "Override high DPI scaling behavior". And underneath that select 'System' for "Scaling performed by:". Then click OK to get out of that box and the original box. Then open VideoStudio.
Does that makae any difference to the the size of what appears on screen.
