Hi All
i'm new to psp, always used photoshop. at the moment i'm finding my way around pretty good, until.....
i downloaded Vision fx, everytime i try to open it up i get error message "failed to load vision fx models" restarted many times without resolving.
does anyone have any idea what i should be checking ?
i'm not tech savvy, found this below on system info:
OS Name Microsoft Windows 10 Home
Version 10.0.19045 Build 19045
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Model 23-f255ea
System Type x64-based PC
System SKU E5F21EA#ABU
Processor Intel(R) Core(TM) i3-3240 CPU @ 3.40GHz, 3400 Mhz, 2 Core(s), 4 Logical Processor(s)
BIOS Version/Date AMI 80.05, 07/06/2013
SMBIOS Version 2.7
Embedded Controller Version 255.255
BIOS Mode UEFI
BaseBoard Manufacturer Hewlett-Packard
BaseBoard Product 2AF9
BaseBoard Version 1.02
Platform Role Desktop
Secure Boot State On
PCR7 Configuration Binding Not Possible
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume2
Locale United Kingdom
Hardware Abstraction Layer Version = "10.0.19041.3570"
Time Zone GMT Summer Time
Installed Physical Memory (RAM) 8.00 GB
Total Physical Memory 7.87 GB
Available Physical Memory 3.63 GB
Total Virtual Memory 11.9 GB
Available Virtual Memory 6.22 GB
Page File Space 3.98 GB
Page File C:\pagefile.sys
Kernel DMA Protection Off
Virtualisation-based security Not enabled
Device Encryption Support Reasons for failed automatic device encryption: TPM is not usable, PCR7 binding is not supported, Hardware Security Test Interface failed and the device is not Modern Standby, Un-allowed DMA-capable bus/device(s) detected, Disabled by policy, TPM is not usable
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualisation Enabled in Firmware No
Hyper-V - Data Execution Protection Yes
hopefully i've not wasted my money, any advice is welcome
thanks all
Vision FX - not loading models
gemini kev
- ram: 4gb
- Corel programs: videostudio 2018
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: Vision FX - not loading models
I don't have this plugin, I use the free InvokeAI program for generative ai, but if it's not loading the models I can only think of 2 possibilities: 1) The model is corrupt and needs to be re-installed, or 2) there isn't actually enough memory while your various programs are running. And there are probably better answers to get from the developers of the plugin.
You can try contacting DistinctAI's support to see if they can give you something better to go off of.
https://www.distinctplugins.io/productscms/vision-ai
Their phone # is at the bottom of that page.
CloudyBright
- motherboard: LENOVO 3750 SDK0T76461
- processor: 3_20 gigahertz Intel 12th Gen Core i9_12900K
- ram: 31 Gig
- Video Card: NVIDIA GeForce RTX 3080
- Hard_Drive_Capacity: 512 GB
- Monitor/Display Make & Model: DELL S2722QC
- Corel programs: PSP9 - PSP2023 - Corel Draw
System Requirements
Operating System: Windows 11, 10 (current maintenance releases, 64 bit only)
Processor: Multicore Intel® or AMD processor with 64-bit support
RAM: 16GB
GPU: Modern GPU with 8GB of RAM
Hard Drive: 6GB
Compatible Software: PaintShop Pro, Corel Painter, CorelDRAW, Adobe Photoshop, Affinity
RAM: 16GB
Hard Drive: 6GB
- sheng-si
- motherboard: Hp motherb
- processor: amd
- ram: 32 Gb
- Hard_Drive_Capacity: 1 tb
- Monitor/Display Make & Model: ASUS VG24VQR
- Corel programs: paintshop pro Videostudio 2022
I have W11, 32 GB Ram Intel core I5-10400 2,9 Ghz.CloudyBright wrote: ↑Tue Oct 17, 2023 2:27 am System Requirements
RAM: 16GB
Hard Drive: 6GB
Hard drive SSD 237 Gb
And still I find Vision FX within psp slow. And worst thing is you can only choose ONE image and then save and close. You start over agiian and get other results.
Admin FB Paintshop Pro NLD for dutch users.
gemini kev
- ram: 4gb
Hi all,
i've reinstalled vision fx still have the same error message - "failed to load vision fx models. please ensure that your gpu meets the minimum requirement before enabling gpu processing."
i only have a basic understanding of computer so not sure where i should be checking or changing. if anyone could give me some guidence it would be very much appreciated, thanks. kevin
Kathy_9
- Hard_Drive_Capacity: 2TB
Okay, here are the minimum system requirements and it looks like you may have an issue with not enough RAM.
Minimum System Requirements:
RAM: 16GB
GPU: Modern GPU with 8GB of RAM (Recommended)
Hard Drive: 6GB
To find your system information go to your Control Panel - System & Security - Security.
or simply type System into the search box to the right of the Start button.
Hope this helps.
RAM: 16GB
Hard Drive: 6GB
Hope this helps.
gemini kev
- ram: 4gb
hi kathy thanks for your reply, i've made a note of your reply, i'll try nd figure how to find the info on my pc. x
