Dear All:
I've a little project I'm working on - of extracting some information from quite elderly microfilm files, of even more elderly newspapers. This project involves the "British Columbian" newspaper from 1862, which was microfilmed many years ago (and not yet digitized). The microfilm reader scans and outputs images (the whole page or sections) from the view on the screen, onto a USB. As you might imagine, the quality isn't all that great. I didn't adjust the settings on the scanner device - just used the defaults.
Basically they are relatively soft images, black and white (albiet in RGB color) with lots of artefact. I've attached a sample.
I've attempted to tidy them by adjusting contrast and histogram up and down and made some improvement but nothing seems to affect the artefact very much. I guess AI models are not trained on elderly newspaper text to automate this for the lazy... Anyone have any suggestions as to how one might go about cleaning these images without doing it all manually? I don't expect to be able to get rid of those big 'scratches' but it would be nice if the background 'pebble' would go away....
Thanks Richard
cleaning text image from ancient microfilm
rnmerchant
- motherboard: Gigabyte
- processor: AMD Ryzen 5
- ram: 16gb
- Hard_Drive_Capacity: 5tb
- Monitor/Display Make & Model: LG x 2
- Corel programs: PSP; Draw
Jean-Luc
- Hard_Drive_Capacity: 2 Tb
Re: cleaning text image from ancient microfilm
Something like this?
Radim
- ram: 4GB
- Monitor/Display Make & Model: 27 inch
If you have scanned images perhaps can help some cleaning software.
In past, when I scanned paper books I used ScanTailor (freeware) - to cut pages, cleanup grayed corners, correct rotation etc.:
https://github.com/scantailor/scantailor/releases
info - https://github.com/scantailor/scantailo ... irst-start
there is also newer version, but I newer used it:
https://github.com/4lex4/scantailor-advanced/releases
and some similar, but commercial program:
https://paperscan.orpalis.com/
Look, if it can help.
rnmerchant
- ram: 16gb
Thanks. I'll have a look at Scantailor.
Though it would be nice to be able to work within Paintshop unless Scantailor does it all (which it may do and that would be fine!!)
Richard
Richard
ConalO
- motherboard: Not Available
- processor: Intel Core i7 1165G7
- Video Card: NVIDIA GeForce MX330
- Hard_Drive_Capacity: 1TB
- Corel programs: PSP 2019 Ult; PSP 2021 Ult;
I am assuming you want to remove the Moire like pattern on the background of this image?
I used Adjust>Add/Remove Noise>Moire Pattern Removal at settings 14 and 4 and then duplicated the layer and set to Overlay.
I then duplicated this new layer two more times to get the attached image.
You can clean this up further with the clone tool.
rnmerchant
- ram: 16gb
Thanks. That's obviously much better.
I tried the moire tool but not with layers and multiple times. I'll give it a try and see if I can get anything like those results!
Jean-Luc
My attempt.
1. Apply the Salt and Pepper Filter: 2. Apply an Histogram Adjustment: 3. Result:
