Apologies if this is a very banal question, but I'm a complete newbie.
How do I join / merge two clips so they appear as one in the timeline?
What I mean is this: let's say that I have 2 clips and I want to show them one after the other.
I drag clip1 onto the videotimeline, then drag clip2 onto the same timeline, just to the right of clip1.
This way, when clip1 ends, clip2 starts.
Now let's say that I have resized clip1 so that it doesn't take the whole screen but only a part of it, let's say the top left part of the screen only.
Once clip2 starts, it will start occupying the full screen.
But I want clip2 to occupy the same space as clip1.
If clip2 and clip1 were one clip instead of 2, I assume I wouldn't have this problem.
Or is there a better way?
If I select both clips, I do not see an option to join / merge them.
There are tutorials on how to merge videos, which talk about transitions but don't address what I need: https://learn.corel.com/tutorials/how-t ... deostudio/
How to join two clips so they become one in the timeline?
YetAnotherLR
asik1
- motherboard: H170M-E D3
- processor: i5-6600
- ram: 8gb
- Video Card: GTX1050-2GB
Re: How to join two clips so they become one in the timeline?
A -put the two on an overlay track, resize 1 and copy it's tribute to the 2nd, 3rd, 4th... n'th.
B- save your 2 clips as vsp > load your vsp as single file ti TL > resize.
Panasonic X900m, VXF1
If we insert the two clips to the timeline, we can then go to Share where we have options to render the project to a single file.
What we choose would generally depend on the properties of the original video files.
Top left for Same as Project Settings, change option to "same as first video clip", assuming those options are available.
However the rendering process is usually left as a final finish to our project
You inserted the two clips and resized the first, you now need to resize the second clip so they both play in the same area of the preview screen.
The program has an option to copy the first clips edits and paste to other clips.
After resizing clip 1, right click Clip 1 on timeline for Copy Attributes
Right Click clip 2 for Past All Attributes
Play the clips in Project playback
YetAnotherLR
Thank you for the answer on copying attributes!
Just so I'm clear, you can trim a clip and make it into 2, but you cannot do the reverse and combine 2 clips into 1?
You can cut / split a clip to make into 2 clips.YetAnotherLR wrote: ↑Sun Sep 17, 2023 3:10 pm Thank you for the answer on copying attributes!
The only way to combine those clips is to render to a new clip using the Share options.
Why would you need to create a new clip out of 1 and 2? When they playback in project mode as one.
YetAnotherLR
Copy and Paste attributes would be quicker than renderring 2 clips into one, replace clips 1 & 2 then apply the edit.
Besides renderring into one clip would then need renderring again, we try to avoid multiple renders as each would affect quality, if we can render once
