Moving Scorefitter files from VS2023 to VS2022
earthshaker
processor: Athlon quad corenm3.66gHz
Video Card: 4 GB Nvidia GeForce GTX745
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: AOC 12269Vw
Post by earthshaker »
I am at my limit of patience with VS 2023, it's just not working as it should.
I already own VS 2022 Ultimate, but the Score fitter music doesn't appear when trying to load it. So what do I need to do to copy those files to 2022 from 2023?
Is it even doable? Do I need to uninstall 2023 in order for it to work or what?
RobertOZ
Hard_Drive_Capacity: 7 TB
Re: Moving Scorefitter files from VS2023 to VS2022
Post by RobertOZ »
First, try resetting the Library,
Go to C:\Users\******\AppData\Roaming\ULeadSystems\Corel Video Studio Pro (x64)
Rename folder 26.0 to 26.0old
Exit and relaunch VS, the library will rebuild and should now include Scorefitter
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
First rename your scourfitter in The VS2022 installed folder.
Then copy the VS2023's one into the the VS2022.
Scorefitter is independent module you can copy it to any VS version since X9..
Panasonic X900m, VXF1
earthshaker
I'll try that thanks!
earthshaker
I finally tried this, but when I opened VS2022, and then clicked on the ScoreFitter icon, after a few seconds, VS2022 crashed and closed, we tried. Thanks
Re – installing video studio should also install Scorefitter
I would uninstall the program using the cleanup tool
https://forum.corel.com/viewtopic.php?t=59847
Then download the programs installation files so using the latest versions to install the program.
