Processing a series of images
rnmerchant
motherboard: Gigabyte
processor: AMD Ryzen 5
ram: 16gb
Hard_Drive_Capacity: 5tb
Monitor/Display Make & Model: LG x 2
Corel programs: PSP; Draw
Post by rnmerchant »
I'm trying to do a series of (manual) edits on a series of photos (I cannot use batch processing as each edit is a bit different).
From within the Edit window, once finished and saved one image, I'd like to open the next in the folder. I'd like to do this within the edit window as going back each time to 'Manage' is a bit slow (even with my fast system).
Is there a way to do this - open the next image within the Edit window'?
Forriner
motherboard: ASUS Z170M-PLUS
processor: Intel Core i5-6400
ram: 16 GB
Hard_Drive_Capacity: 1250 GB
Monitor/Display Make & Model: Philips Brilliance 272b 2560 × 1440
Corel programs: PSP 2023
Re: Processing a series of images
Post by Forriner »
You can open the Organizer Palette in the Edit workspace: menu View/Palettes/Organizer -or- keyboard shortcut Shift+F9. This toggles the palette. There you can navigate to the folder you need.
You may need to be in the Complete workspace.
rnmerchant
ram: 16gb
Thanks for this. Seems to be a reasonable solution.
I thought initially that the amount of screen 'real estate' was too much but it can be sized so I'm very happy with the way this is currently working for my relatively simple but repetitive task!
Cheers
