Magic Fill Shortcut Key
jrmach
motherboard: Intel Z170
processor: i7 7700K
ram: 32g
Video Card: 4095MB NVIDIA GeForce GTX 1070
Hard_Drive_Capacity: 6 tb
Monitor/Display Make & Model: PnP-Monitor (Standard) 1920x1080 pixels 120Hz
Corel programs: Pretty much all of them except cad....?
Post by jrmach »
Is there a way to assign a shortcut key to the Magic fill? I could not find magic fill in the customize section or am I missing something?
(o o)
-ooO--(_)--Ooo-
Jrmach
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Magic Fill Shortcut Key
Post by LeviFiction »
I don't think there is a way to do it directly, but there is a workaround. You record a script that only does the magic fill, then bind the script to an icon, and then attach a keyboard shortcut to the bound script. Now, any time you have a selection you can use the shortcut.
Setup is the hardest part and it's very easy.
1) Make a selection
2) On the script toolbar (if you don't have it open, go View->toolbars->Script) hit the red record button
3) Run magic fill
4) Save Script on the script toolbar, name it something like "Magic Fill"
5) View -> Customize
6) On the customize dialog select the "Scripts" tab.
7) Select your script from the drop-down list and an icon you want to bind it to.
8) Click the "Bind" button. This script can now be added to toolbars and menus, and can also be given a shortcut key.
9) Click the "Keyboard" tab
10) Select "Bound Scripts" from the drop-down list of menus.
11) Select your bound script
12) Find a shortcut key you would like to use
13) Hit OK to save the change.
14) Save your workspace for easy retrieval should you need to reset the workspace at any time.
jrmach
processor: i7 7700K
ram: 32g
Post by jrmach »
Thank you so much LeviFiction, it is greatly appreciated and spot on.
(o o)
-ooO--(_)--Ooo-
Jrmach
