I reinstalled windows 10 a week a go and did reinstall psp 2017 and 2022 but non of them have the foreground/background gradient by default.
How/where do I get it for my 2 programs?
Missing foreground/background gradient
Kathy_9
- Hard_Drive_Capacity: 2TB
Re: Missing foreground/background gradient
Here you go.
- Attachments
- Corel_06_029.zip
- (197 Bytes) Downloaded 63 times
CloudyBright
- motherboard: LENOVO 3750 SDK0T76461
- processor: 3_20 gigahertz Intel 12th Gen Core i9_12900K
- ram: 31 Gig
- Video Card: NVIDIA GeForce RTX 3080
- Hard_Drive_Capacity: 512 GB
- Monitor/Display Make & Model: DELL S2722QC
- Corel programs: PSP9 - PSP2023 - Corel Draw
I lost that default gradient after upgrading to 25.2.0.58
My corel_06_029 gradient does not have the stair-step gradations like it used to have. The gradient now looks like a fade from black to white.
Here's a image of how the gradient used to look. Does it not appear that way anymore???
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Okay, umm......just need some clarification. Is that an "example" of what you expect the gradient to look like? Or is that an actual screenshot of the gradient you're referring to?
Because that's the HSL map on the materials palette, and it looks like that only because you have a mask layer selected and a mask layer is a greyscale image. So it'll look step-laddery on the HSL map. But the actual GRADIENT file is meant to be smooth. It's quite rare that someone actually wants the banding. Banding is usually a result of not being able to represent any colors in-between two colors creating a sharp transition. The banding is most noticeable once applied to an image as it needs to represent all of the in-between colors over a larger space than the swatch panel.
CloudyBright
- ram: 31 Gig
Yes, that's an example - a screen shot from a PSP tutorial on YouTube: https://youtu.be/lBdVzz_13qk
My PSP gradient used to look like that- but not anymore. So, then might I assume that's okay? A fade from black to white, with no stepping, is okay?
- ram: 6 GB
In my opinion, having never seen a stepping gradient of the type you describe. Yes, yes it is okay.
CloudyBright
- ram: 31 Gig
I found the stepping gradient will show if I click the HSL button just below the 'Materials' shown in the image above.
- ram: 6 GB
Okay. And that's what I meant in my original question. If the screenshot was a screenshot of the actual gradient, or just an example of the appearance of any gradient that matched what you wanted. It's why I mentioned that in the example you show is the HSL Map on the Materials palette and looks like that specifically because of Greyscale images or layers. It's a color picker in the appearance of a gradient, not a gradient resource which is what most people will think of when you say "Gradient".
