PaintShop Pro 2023 Update 2 Released
Radim
- ram: 4GB
- Monitor/Display Make & Model: 27 inch
today we get a big update for latest PaintShop Pro with a lot of changes.
See for yourself - download:
https://www.paintshoppro.com/en/support ... /#psp-2023
List of changes:
https://www.paintshoppro.com/en/support ... date2.html
PDF manual was updated also:
https://help.corel.com/paintshop-pro/v25/index.html
[version 25.2.0.58]
List of changes:
[version 25.2.0.58]
sdracup
- motherboard: CML Stonic
- processor: Intel Core i7-10750H CPU
- ram: 12GB
- Video Card: NVIDIA GeForce GTX 1650 Ti
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: HP 24er
- Corel programs: Paintshop Pro Ultimate 2023
Re: PaintShop Pro 2023 Update 2 Released
I installed the new update, but according to the release notes there is a new enhancement - New! Haze Removal: Reduce haze in your photos in a few clicks (Adjust > Haze Removal).
However, I cannot find it anywhere. It is not in the adjust menu, and not in the view customize so I can add to the menu?
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
@sdracup - if you go to help -> About...
What is the version number you see? You should see 25.2.x.x (those Xs might be 0.58, but the 25 (2023) and 2 (update 2) are the important parts)
If you reset your workspace to defaults do you see Haze Removal?
I did a full re-install earlier this week and it was already on Update 2 so I can't compare to installing the update on top of 2023. I see Haze removal in the Adjust menu under the "Softeness" menu and before the "Skin Smoothing" option. It's similarly found in the Customize dialog between the same options.
sdracup
- ram: 12GB
Hi, I did the workspace reset, and the dehaze is now showing up. Thanks for the help.
JoeB
- ram: 8 GB
- Hard_Drive_Capacity: 4.6 TB
Curiosity question. A workaround for removing haze in previous PSP versions was to use the Fade Correction filter. It worked fairly well and also helped with underwater pictures. does the haze removal filter in the 2023 update work better?
JoeB
Using PSP 2019 64bit
JoeB
- ram: 6 GB
For me in my personal tests. I prefer it to the usual workarounds. But it's not a perfect solution. You may find yourself using it in conjunction with other filters to get a better result. But it wasn't always better, sometimes they were almost identical. Sometimes the results could be identical if I added fill light/clarity filter.
patara
- motherboard: ASUS Prime Z690 DDR5
- processor: Intel i7-12700K CPU 12 Core
- ram: 32 GB
- Video Card: GeForce GTX 1060 GI Gaming 6G
- sound_card: VIA High Definition Audio
- Hard_Drive_Capacity: 1TB SSD +22TB Hard Drives
- Monitor/Display Make & Model: Dell U2715H
- Corel programs: PSP7 to PSP 2023
Haze Removal was also missing for me after I installed the Patch.
I used View/Customise to drag the tool into the correct place in the Adjust Menu. I tested it and it is working.
Jimb610
- System_Drive: N/A
- processor: i5-8400T
- ram: 12GB
- Corel programs: PaintShop Pro 2023 Ultimate
I can't get the update to install. I currently have 25.1.0.28X64 so I should be able to install the 25.2 update.
I click on the link download then open the file. Then the Installation Wiz runs and the status bar goes all the way to the right. After a minute or so I get a window that says No update of your installed software is required at this time. Click OK then get a window that says the update wasn't installed and there was a fatal error. Yesterday (Friday afternoon) I emailed Corel support but haven't heard back yet.
Anyone else have this issue?
Radim
- ram: 4GB
See more about supported versions of Windows 11.
Jimb610
- System_Drive: N/A
- ram: 12GB
OK I will. I'm running Windows 11 Insider Program Beta Channel.
As far as i know PSP with SP1 was version 25.1.0.32, at least that is what i had.Jimb610 wrote: ↑Sat Aug 12, 2023 3:21 pm I can't get the update to install. I currently have 25.1.0.28X64 so I should be able to install the 25.2 update.
You may be best to uninstall the program, then download the installation files again, that should install PSP including SP2
sdracup
- ram: 12GB
The update must be having issues. I had 2 files open, and copied one and added as a new layer to the other. I did blending, but every time I try to merge the layers, the program is crashing. I did a reboot, and it occurred again. 3 times now. I guess I will have to open a case on it.
Kathy_9
- Hard_Drive_Capacity: 2TB
sdracup
- ram: 12GB
I did all the resets, and the issue is still occurring. I opened a case. Thanks for the help.
SJS
- motherboard: Dell Inc 0KWVT8 A03
- processor: 11th Gen Intel Core TM i7-11700
- ram: 16 GB
- Video Card: NVIDIA GeForce GTX 1660 Ti 6GB GDDR6
- sound_card: Onboard Realtek Codec
- Hard_Drive_Capacity: 4 TB
- Monitor/Display Make & Model: DELL U2412M
- Corel programs: PaintshopPro 2022 Ultimate
Thank you for this hint!
