Weird lined flashing area after render
Colleen
motherboard: ASRock B365M Pro4
processor: Intel Core i7-9700K
ram: 16 GB
Video Card: GeForce GTX 1660
sound_card: high definition
Hard_Drive_Capacity: 2 TB
Corel programs: VS X7, VS 2023
Re: Weird lined flashing area after render
Post by Colleen »
Oh I also removed mask
Hi Colleen
I have tried again to replicate the problem, each time I start a new project all works ok
Trying to modify your project, remove the crop or mask and I get some strange effects.
I just cannot fix your VSP.
I then created a project using X9, the oldest version I have installed.
At first that worked ok, after a few test projects it started acting up.
I am convinced there is some conflict with older X9 projects and 2023.
I have created a project and saved as a Smart Package for you to view.
The rendered M2T video is on the top track.
All I can suggest is to replace the Images with the video, you may need to create another video at the correct length.
Lata Dog.zip
VSP opens with 2023
(13.14 MiB) Downloaded 45 times
Colleen
ram: 16 GB
Post by Colleen »
Thank you. I can get it to work if I start my project with X7 and then open in 2023. I can't start with 2023 though. Anyway I was able to make the 4 picture video and cut and paste into my original just fine. I just hate that I have to use this work around. When building a project in 2023 I need to be prepared to revert back to X7 for various failures. Just sucks.
zaphodikus
motherboard: ROG-X570-F-Asus
processor: AMD 3950 - 16 core
ram: 64Gb
Video Card: AMD RX 6700
Hard_Drive_Capacity: M2 1TB
Monitor/Display Make & Model: 4K BenQ
Corel programs: VS 2023 Ultimate, Painter 2020
Post by zaphodikus »
Intrigued, I last saw this kind of interlacing problem happen years ago, cannot reproduce the issue in 2023. So this happens when you create a new project, or only when you import from X7?
Colleen
ram: 16 GB
Post by Colleen »
The disturbance happens when I start in 2023. I got it to work by starting in X7 and finishing in 2023. Since then I've tried a few more times from scratch in 2023 and I'd say 1 out of 4 times in worked. I don't know why.
zaphodikus
ram: 64Gb
I would try a different computer before throwing it all in, I assume you uninstalled 2023 and cleaned out and installed again? From here it's looking like a codec problem, but I mostly wonder if it's the blue-ray project profile defaults that is the cause? Really sux when you are trying to make a videodisk to have to struggle.
zaphodikus
I have tried to rectify the VSP sample provided by Colleen but each time fails.
I can create a new project from scratch with no problems creating the effect.
Its a portrait image that has Customise Motion effect to increase size / a little zoom.
Then the background is using same image, distorted and blurred to fill the borders.
Nothing difficult there
The original VSP was created by VS X7 and that i believe there is a problem of compatibility / conflict.
to add some crop and mask has been added in error as these are not required, easily removed.
The only option i can think is to create a new vsp using 2023, render to video, replace images in main vsp with video.
