Photo display time in slide show
earthshaker
- processor: Athlon quad corenm3.66gHz
- Video Card: 4 GB Nvidia GeForce GTX745
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: AOC 12269Vw
I have 7 minutes of audio and three photos on a timeline, is there an easy way to match the display time of the three photos to match the length of the audio?
- RobertOZ
- Hard_Drive_Capacity: 7 TB
Re: Photo display time in slide show
Highlight an image on the timeline, place cursor on right edge, an arrow will appear, hold down mouse button and drag to the length required
earthshaker
I tried that, but then I mess around with re adjusting all three photos repeatedly, until it's close enough. There should be away without all of the messing around.
Thanks anyway
Thanks anyway
- RobertOZ
Right click on image, select photo duration, set required time
earthshaker
Then again I will have to adjust all three individually unless I select all
of them right click and choose duration of the group. I will try that
- RobertOZ
Yes that will work
Alternatively, Go to Settings/Preferences/Edit
Default photo/color duration, set length, (but only allows for full second increases), now all images will be of same length,
earthshaker
Thank you
- zaphodikus
- motherboard: ROG-X570-F-Asus
- processor: AMD 3950 - 16 core
- ram: 64Gb
- Video Card: AMD RX 6700
- Hard_Drive_Capacity: M2 1TB
- Monitor/Display Make & Model: 4K BenQ
- Corel programs: VS 2023 Ultimate, Painter 2020
I often create a scratch track below and drop things like a copy of a photo that I have at my ideal length and have ideal motion attributes of. And then use it as a "guideline/template" and just shift it about wherever I am working in timeline, and can also copy it's properties to apply them to any photo.
