Could someone explain what the following options specifically do - when enabled or not enabled - when using the "Free Rotate" Image Effect?
- All Layers
- Rotate single layer around canvas center
With both options possibly selected or not selected, that should result in 4 different permutations (and 4 different potential results), yet I can only determine and demonstrate two results. Is my understanding of the first option correct? And what does the second option do? The "Help" menu also seems to omit this option from its entry on the "Free Rotate command" entirely.
An explanation would be helpful - an example of how to demonstrate the difference would also be insightful (as learning through experimentation is helpful to me).
(For reference, I'm using Paint Shop Pro 8 - though I imagine the explanation applies to later versions as well. If you only know the answer for later versions, that might still be helpful and applicable)
