PSP Plugins 2022
Leslie
processor: intel core i7
ram: 32 gb
Video Card: intel iris
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: Dell Inspiron 7700 27 All-in-One Desktop
Corel programs: 2019 Ultimate, 2022 Ultimate
PSP Plugins 2022
Post by Leslie »
I cannot get my plugins to show up in psp 2022. I add the correct locations, open and close psp, but the plugins do not show up in the program.
Can someone help, please?
Thank you,
Leslie
Re: PSP Plugins 2022
Perhaps to state the obvious, if the plugins are 32 bit, they will only show up in the 32 bit version of PSP, and not the 64 bit version. 64 bit plugins will of course show up in the 64 bit version of PSP. Can we assume you installed both the 32 bit and 64 bit versions of PSP?
Leslie
ram: 32 gb
Post by Leslie »
Yes, I have both installed. I have no problem with psp 2019
Kathy_9
Hard_Drive_Capacity: 2TB
Post by Kathy_9 »
And, have you pointed to the folder with your plug-ins via File Locations?
Leslie
ram: 32 gb
Post by Leslie »
Yes, I have. I have even put the ones on C drive that won't work otherwise
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
Leslie wrote: Fri Jun 30, 2023 10:32 am Yes, I have both installed. I have no problem with psp 2019
Although you have both 32 and 64bit versions installed, you haven't said whether you are trying to open the plugins with the 32bit version rather than the 64bit version??
JoeB
Using PSP 2019 64bit
Leslie
ram: 32 gb
Post by Leslie »
I use the 32 bit version. All my plugins work fine in psp 2019. I took some of the file locations out in 2022, and the plugins were still showing up. Isn't that strange? I thought they would be out of the effects list. I just don't understand why they are still showing up. I want to import to Filters Unlimited instead of having lists and lists of plugins In the drop down one for effects. So I want to start over with adding plugins.
Thanks,
Leslie
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
I'm assuming you restarted PSP after removing the plugins from the file locations.
As I'm not on your computer and can't look through things I have to assume that, if PSP restarted or re-cataloged all plugins in the folders and they're still showing up (since it loads them on startup or on refresh) that similar plugins are still being referenced in other folders or locations. I don't believe PSP caches and loads a database of plugins.
Leslie
ram: 32 gb
Post by Leslie »
I re-started psp, but that didn't help. Then I re-booted the computer and that cleared the list.
Thanks for your help.
