Problem Exporting .tga files
PapaJeff
ram: 16 GB
Video Card: Radeon RX 580
Post by PapaJeff »
I have just upgraded from PSP8 to PSP22. With version 8, I could save a graphic as a .tga file and use it in another program. However, when I attempt this in version 22, it doesn't work right. The error message I receive is "Only 256, 24 bit, and 32 bit are supported." I check marked the 24/32 bit box. I've tried the other options. I have tried each option compressed and uncompressed. I keep getting the error.
If I save as a png, then run it through a converter, it works fine. With the old version, I didn't need this extra step. i'm pretty sure I am missing something somewhere. Any assistance would be greatly appreciated.
PapaJeff
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Problem Exporting .tga files
Post by LeviFiction »
Quick note: I'm on 2023. Though I don't think there was a TGA fix between versions mentioned anywhere to make me think 2022 would be any different.
I have no issues saving to TGA format. The only error message I get is that it's going to flatten my layers and that I have to put any transparency into the alpha channel before saving or transparency will be lost, or that a 16-bit image will be downgraded to 8-bit. In this case the language is a bit different. 8-bit being 24bit or 32/bit with an alpha channel.
In all cases I tried, the errors are warning you about what changes they'll make to the image before saving but they do save. Any chance you can show us a screenshot of the error, and the Image Information Dialog?
Have you tried resetting PSP to factory defaults in case there is corruption?
