Play List Not Working
Burn
Post by Burn »
Ok let’s see if I can explain this. I have made my first DVD and the play list isn’t working correctly when the film is burned either to an image, DVD folder or DVD it works perfectly from the DVD emulation which is built in Ulead DVDWorkShop 2.0 As you can see from this pic what should happen is, the Video I made “BRF” should play then it should go to “Menu-01” but what happen is it plays “BRF” then it goes to the main menu not “Menu-01” that’s the first problem.
The next problem is when I play the “BRF” if I press the skip to next chapter it goes to the next chapter in “BRF” but when it gets to the last chapter it doesn’t go to the Menu instead it plays the next video which in this case is "injection" I didn’t even put this in the play list. If I don’t press the skip to next chapter button and just let it play, at the end it will then go to the Menu but not the menu I have told it to go to “Menu-01” it will just go to the Main Menu. I hope that’s explained it clearly enough. Any help would be great. I think it’s a bug in the program but I could be wrong
Like I said everything works perfect on the DVD player built into Ulead DVDWorkshop it’s when it’s burnt to an image, DVD folder or DVD that the problems occur
GeorgeW
Post by GeorgeW »
For your first issue -- are you letting the DVD Play through -- or are you hitting the NEXT or FF button? If you let it play on its own, it should follow the playlist items.
For your 2nd issue, have a look at this thread:
DVD Next Button
George
Burn
Post by Burn »
If I press FF it will go to the next chapter because I made 12 chapters in “BRF” when it gets to the last chapter, chapter 12 if I then press FF it will skip going to the Menu and play then next film “Injection” If I let it just play and not press FF it will then go to the menu. The only problem is, it’s not going to the menu I told it to go to. I told it to go to Menu-01 but it’s going the main Menu.
So is there a way that when it's on the last chapter of BRF if I press FF it will go back to the menu like I’m telling it to? And why will it only go to the menu, when I let it play through and not when I press FF?
If I let the "BRF" video play through, why does it not go to the Menu I told it to go to?
I’m using Ulead DVDWorkShop 2.232 full Version. I made all these Video files using Ulead Media Studio Pro 7.30.0001 Full Version, and encoded the Video Files to Mpeg2
