Hello,
I have a logo which consists of 3 triangles with angles of 30-60-90. I want to animate the triangles in a banner for my website so the triangles rotate around all 3 axes from right to left one at a time.
At the end of their tumbling routine, the triangles come to a stop with one on top of the other, but also with each subsequent triangle having moved "up" the Y-axis so that the triangles which are "behind" another are partially visible.
The above I have done successfully...it is the next part which confuses me.
The right-angle of each triangle is at the bottom left. I want each triangle's right-angle to twist together so that the triangles are connected by the twisted bottoms. Each triangle is a different color (blue, purple, orange), so the twisting would look like a multi-colored twisty soft ice cream cone.
Every time I try and twist only the bottoms (i.e., the right-angles), I cannot seem to get a uniform twist so that all triangles are tied together by their twisted parts. I have been adding points and trying to use the Bezier lines to twist. I also tried the twist/rotate function already in C3DPS, but that warps/twists the entire triangle, not just part of it.
Can anyone help me to twist my right-angle triangle bottom? (I cannot help but laugh at how that sounds, but I am serious.)
If C3DPS is not the appropriate program to do this with, can I do it with PhotoImpact? Any other program anyone would recommend?
Thank you,
edsager
Twist part of object
edsager
Re: Twist part of object
Yes, but my demo time ran out before I started on my logo.
Any other suggestions?
Thank you,
edsager
Thank you,
edsager
edsager
Maya is a beautiful piece of software, but very expensive.
Am I out of luck with trying to do my project in C3DPS?
Thanks,
edsager
Thanks,
edsager
