Borders in overlays in VS2023
cybernick
- Video Card: GTX 1060
- Hard_Drive_Capacity: 1TB nvme
- Corel programs: Video Studio 2020&2021 Ultimate
I really do not understand why when I set borders in the overlay in VS2023 there is "chop" in the upper right corner.
I really do not understand, we started having bugs in the simplest features.
- RobertOZ
- Hard_Drive_Capacity: 7 TB
tletter
- processor: i7-3632QM
- Video Card: NVIDIA RTX 3080
Re: Borders in overlays in VS2023
If you're using the Picture-In-Picture filter to create the border then a similar issue has been around since at least VS2018 (see image). Adjusting the Shadow Blur will get rid of the "chop".cybernick wrote: I really do not understand why when I set borders in the overlay in VS2023 there is "chop" in the upper right corner.
tletter
asik1
- motherboard: H170M-E D3
- processor: i5-6600
- ram: 8gb
- Video Card: GTX1050-2GB
This is new tletter, can you share such 2018's vsp with sample files? I have 2020 and 2023 for the test.tletter wrote: ↑Wed May 03, 2023 5:53 amIf you're using the Picture-In-Picture filter to create the border then a similar issue has been around since at least VS2018 (see image).cybernick wrote: I really do not understand why when I set borders in the overlay in VS2023 there is "chop" in the upper right corner.
tletter
Panasonic X900m, VXF1
- RobertOZ
Well I have VS2018 installed and don't see cut corner, so yes a sample .vsp file would be useful
tletter
Actually asik1, it's not new, as it's been around since at least X8. The only new thing is that someone raised it on this forum.asik1 wrote: This is new tletter
Yes, see enclosed X11 SP. tletterasik1 wrote: can you share such 2018's vsp with sample files?
- RobertOZ
That file does not help us, what we need is a copy of the original image used in the PiP ( the 3 ladies)
tletter
Why the hostile tone?RobertOZ wrote: That file does not help us,
It's a Smart Package with all the required files. Pls let me know if you need help opening the ZIP file and opening the VSP in VS.RobertOZ wrote: what we need is a copy of the original image used in the PiP ( the 3 ladies)
tletter
- RobertOZ
OK, used your file in VS2018, as you can see, there are no cropped corners using PiP, or maybe I am trying PiP different to you
cybernick
You should put a border.
tletter
No idea why you decided to modify the VSP (see image showing the original project and your changes), and then make a bogus claim. However, it was noted that you couldn't open the ZIP file, so that may explain it.RobertOZ wrote: used your file in VS2018, as you can see, there are no cropped corners using PiP
Some of your meddling includes:
- use of the "Replace last filter option"
- changing the background image
- removing the text
tletter
asik1
- ram: 8gb
That corner came from the NB PIP's shadow,
As your size is just 98.5, the shadow has no room to do it's thing...
If you 0 it's offset, that corner will be corrected.
cybernick
I do not consider this as a solution. That would affect my workflow negatively. So I simply want to have a simple overlay feature available.
asik1
- ram: 8gb
There is a simple proper feature for it, it calls custom motion.
cybernick
Any patch yet?
