Which Version to Buy?
Linda Lou
- processor: Intel i7vPro10th Gen
- Hard_Drive_Capacity: 1024 GB
- Monitor/Display Make & Model: ThinkPad Extreme Gen3
- Corel programs: PaintShop Pro 7, 8.1, 2018, 2023
Re: Which Version to Buy?
Well, My Goodness there they are!!! (I would have more if they had saved my JASC's. Thank you, Kathy.
patara
- motherboard: ASUS Prime Z690 DDR5
- processor: Intel i7-12700K CPU 12 Core
- ram: 32 GB
- Video Card: GeForce GTX 1060 GI Gaming 6G
- sound_card: VIA High Definition Audio
- Hard_Drive_Capacity: 1TB SSD +22TB Hard Drives
- Monitor/Display Make & Model: Dell U2715H
- Corel programs: PSP7 to PSP 2023
I used the Plugin Bridge in PSP 2023 64 bit. Some FM filters don't work in it. I find it useful though for many 32 bit filters and FF filters inside FU work fine in it.Linda Lou wrote: ↑Thu Apr 27, 2023 4:23 pm Thank you so much for the additional info. I'll check the upgrade price at the link you posted. That is close to the Amazon price, so I'll probably order from Corel. Once activated, is there an account ID key attached somewhere that I can make note of and use for installation if I get a new computer?
That plug-in bridge specifies Adobe PS, Corel Painter and Affinity Photo. There is a trial dated June 2017. Has anyone used it on PSP 2023? If so is it easy to install and use?
I'd advise not pointing it to your Plugin folder but add them as you need. When I set mine up I pointed to my normal Plugin Folder and it added filters one at a time and I ended up with 1000's of Sapphire filters listed one by one and so far the only way I can remove them is one by one.
Linda Lou
Thank you for the info! Yes, I would probably have pointed it to the Plugin folder. Good thing you told me that!
Linda Lou
I'm really liking 2023.
I had a question about opening images, but I think I figured it out, so I've removed the question. I don't see a way to delete the entire post.
