I was alerted at having same brushes at multiple locations. My PS 2023U was a new new installation on a new laptop that did not have an older version of PSP.
1. Which folder is the default when brushes get installed?
2. Should I simply purge one set by overwriting into the other (same set)?
3. Any idea how the duplication occurred?
Tnx,
Multiple Brush Folders - which to delete?
- iraisok
- motherboard: Dell 0X501H
- processor: Intel i7 960 Quad Core
- ram: 24GB
- Video Card: ATI Radeon HD 5870
- sound_card: Creative Sound Blaster X-Fi Titanium
- Hard_Drive_Capacity: 4.5 TB
- Monitor/Display Make & Model: Dell U2410 24" Wide, Dell 1905FP 19"
- Corel programs: PSP2019U, PhotoZoom7 Topaz Remask
Ira
PSP 2019U on my desktop with Win 10 Pro; PSP2023U on my laptop with Win 11 Home, each with GFRX, PicToPaint, Topaz ReMask, BenVista PhotoZoom 7 and a few personal scripts.
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: Multiple Brush Folders - which to delete?
Starting at the bottom of the list you posted.
Those installed by PSP and most installers will probably go into the ProgramData folder.
Those purchased through the store that don't have a separate installer will go into the "Purchased" folder.
And ones that you make yourself, download from other sources, and export from inside of PSP will go into the top folder the normal "Brushes". Usually, the top folder is the default folder for any resources you export yourself.
In some cases, the brush may not be duplicated but might have the same name. For example if I downloaded some watercolor brushes from a website and then bought a watercolor brush set from Corel's store. I might end up with some brushes the same name but from different sources. So you'll want to confirm the brush head and settings before purging. Sometimes you can simply rename them.
The first place to purge from would be the standard brushes folder if any are in there. Because as stated previously, the other two folders are where Corel officially installs purchased brush packs.
- iraisok
- ram: 24GB
Hi Levi...,
[Great to hear back from you. We have history with Pic-to-Painting. I was easily able to configure in my new environment 9keeping old on Desktop, BTW using your updates as they all were needed.]
Back to subject;:
1. I NEVER used or created brushes nor have I ever exported any.
2. I don't know how to view brush file names from w/i PS Complete Workspace that I use to know from which folder they are used?
3. There are no files in C:\Users\ira\Documents\Corel PaintShop Pro\2023 or any of its subfolders. Should I delete the 2023 subfolder?
4. C:\Users\ira\Documents\Corel PaintShop Pro\Purchased\Brushes\ subfolders Brushtip_2023 and Creative Brush Pack (with it's subs) appear to be a subset of what is in C:\ProgramData\Corel\Corel PaintShop Pro 2023 Should I delete the subfolder in Documents?
Thank you,
Back to subject;:
Thank you,
Ira
- ram: 6 GB
Don't delete the 2023 subfolder. There's no point. Those are created automatically by PSP for anything you create. If you delete them PSP will just create them again.
I wasn't suggesting looking at brush names inside PSP. As I don't think you can see filenames. Though, the name of the brush will match the file name of the brush in 89% of all instances. There are some brushes that use a translation file to change the name.
But if you want to rename, move, or delete brushes from inside PSP you can use the resource manager. Just scroll open the brush head selection dialog, and click on the button underlined in this image Then the resource manager will open. Here you can move, delete, copy, and rename brushes.
- iraisok
- ram: 24GB
Final I think
I don’t want to see the warning appear that shows duplicate brushes. I am confident they are duplicates.
Which files (not folders) should I delete from which folders.
Ira
- ram: 6 GB
Whichever ones you want. If you rename the duplicates you'll still have duplicates but you won't get the warning. So if you're worried about it just rename them. Otherwise either works because it doesn't actually matter.
